EGA Converter problem
madlok
22CR
Hello, my Indy 500 - a neverending story.
I replaced a
Monitor with a TFT using an EGA Converter(photo) and the picture is ok, I
read posts the picture is lousy, but I really think it´s good...for 2
Minutes. Then it turns red more and more. At the end it´s hard to see
anything. I can´t find a button or anything that helps to save the
original setting. I press 1 of the 4 buttons and the picture is good
again- for 2 minutes,I don´t find a setting to save it.
Any help,please? Someone familar with that converter?
Cheers, Frank.
Kev A
747CR
Easy fix. You need to lower the clamp sp setting. I cant remember exactly but one needs to be higher than the other. If you set one to 05 and one to 04 it should hold the colour
Cant make the link clicky but heres a video.....
https://youtu.be/V9rrQOc4IUY
Kev A2020-09-28 20:52:21
Kev A
747CR
They have a ittle bit of lag in stock form and some people report syncing issues with some older boards but for the £15 or so cant complain really. There are modifications and custom firmware that improve them.
madlok
22CR
Wow, I´m so glad I received answers, I have this problem for a while now, was almost desperate.
Kev, thank you for the Link, seems to be exactly my problem, I will try tomorrow.
Van, as Kev said, for approx 15 you can´t do it wrong, by the way -I never saw any lags, all I realised was that the colors were a bit more watery, on the other side the picture seems sharper
Vas- thank you for the Link, looks very interesting, but I am really bad at soldering, so it is nothing for me, but was cool to see it, and I saved it, maybe a friend can do it for me, thank you.
I will post again in 1,2 days, when I tried the clamps.
Thanks to all of you:)
Kev A
747CR
no worries, I had exactly the same issue, using one with a Sega Rally board. After making the changes it worked just fine :)
