Electrocoin SCI Tidy Up
r-type
633CR
Afternoon all,
I'm trying to tidy up my SCI cab and wondered if anyone has any tips for removing the steel kick panel found on these cabs (and Chase HQ I think) as I'd like to replace the rubber matting.
It appears to be held on with some round, domed head pins with a very loose thread on. I've tried using a dremel to cut a slot in them to back them out but that doesn't seem to work. The one that I did get out was quite loose and I worked it out with pliers in the end.
I'd rather salvage the steel if possible, but wondering whether I may have to pry it off and keep it in good enough shape to get a fabricator to make a new one up.
Has anyone got any ideas please?
Andy
Mr20to5
1,366CR
You will be able to get at them from the underside of the foot plate. Where they will just be nuts or similar that you can remove and then the bolt, then the metal flashing.
Mr20to5
1,366CR
For the rubber matting if you have a 'The Range' store near you, if you go in and look at the shelves holding the picture frames, you will find that they use an almost identical matting to prevent them slipping off the shelf.
A sweet word into the ear of a well chosen member of staff should see you walk out with enough of an off cut, for your needs.
r-type
633CR
Thanks for the reply Neil,
Looking at that cab, the fittings are different. Mine are definitely not bolts. Nearest thing I can find to them are 'Drive nails'.
I picked up some matting on ebay which is a perfect match.
7,230CR
So there is nothing at the back ?? Only other way is to drill them out - But if they just spin that wont be easy either.
P.S Just guessing never done one !
Mr20to5
1,366CR
If you have checked and there is nothing on the back, then dremel a notch into the head and screw them out. Hopefully enough to get a hold with some pliers.
r-type
633CR
Easiest thing in the end was to dremel the heads off the pins completely, so they were flush with the plating. After doing all of them, it finally lifted off.
