Electrohome G07 issue
namfreak
92CR
Hi Guys
Wonder if you guys can verify whether I'm on the right track or barking up the wrong tree
Electrohome G07 is getting 120V (tested at SU 11) from the PSU, but no glow from neck guns (screen blank)
Have checked fuses F901 and F902 for continuity - not blown
Have tested for 120VDC at R1 (large white sand resistor on side of chassis). Expect 120VDC to 145VDC depending on which side I test. I get 6.5VDC
The flow chart then suggests Filter cap C904 may be bad of the R1 voltage is low.
Am I on the right track?
funhouse
362CR
I know from experience that it is easier for people to recommend actions if you post the schematic image up and possibly mark the positions of the components you've looked at.
