Electrohome G07
petercasino
212CR
I've just done a cap kit on a 13" Electrohome G07 F0B. There were about 4 capacitors that I replaced that had different capacitance values in the kit - I never seen that before. The bottom right of the picture after doing the cap kit looks like its slightly off. Is this caused by the different cap values or something else?
tb2000
3,584CR
There's a slight chance it could be. If the caps you changed were the originals, I wouldn't change the values, you're best off matching the new caps to the old. You might want to either turn down the screen control or the blue cut-off also.
petercasino
212CR
It looked like it might've had a cap kit before. I have a note of which ones were different - do you think it's worth me changing those ones back (with new capacitors)?
I will adjust the screen as suggested - thanks.
gunblade
9,144CR
I should rephrase this, some companies are offering the correct values but others are not- I have seen it with my own eyes, in particular Japanese built chassis. There are a lot of U.S based sellers that do these kits and some extremely important caps are completely wrong value- classic is 0.47uf on the ms8-26 I think I recall
