EPROM horror pic
ragnar0k
13CR
Hello,
Just got this SNK bootleg and of course it doesn't work. Now, I saw some really horrific stuff done to those poor EPROM, was wondering if anyone of you has seen it ever?
Looks like they daisy-chained the eprom together?
Of course, this is the result... (By the way, can anyone recognise the game?! My GQ-4X refuses to read those EPROMs)
markjw
23CR
looks like they didn't have the right size EPROM for the board (27C1000D) so have used a pair of 27512 (half the size) in its' place.
Would think the pin where the wire has been soldered is cut off (this looks to be Output Enable) and is connected to whatever chip is enabling the EPROM to select between the two chips.
You might be able to read each EPROM individually - could be one is the lower half of the code and the 2nd the upper half and then join the files together to see what you get
markjw2015-05-26 15:01:41
markjw
23CR
saw a similar idea years back, but much more professionally done - some of the early Acorn BBC Micro computers had a daughterboard fitted into one of the EPROM sockets with two EPROMs installed on it
From memory this was to allow them to use a pair of 4K chips rather than a single 8K - suspect this was due to either a shortage or high cost of parts early on.
grobda
1,061CR
Seen it more with RAM chips, Bomjacs wishaw haul of bootleg galaxian hardware PCBs had dozens of piggybacked 2114s. PITA as they're a main contender for 'most likely bad chip'
And Paul Swan's 'par type' hack does it too. As long as its hooked up right it should be fine. Ugly, but functionally correct.
Macro
2,010CR
yep, extremely common both as a hack and as mentioned where the existing 'larger' eprom / ram was unobtainable or expensive.
mind you, they didn't even fit a big enough socket for the '010 from the looks of things
grobda
1,061CR
i wouldnt bin it. If i cant fix them or they run like crap compared to an original I use pulls off them to repair other boards.
oh and a 1mbit eprom will cost you about £2
grobda2015-05-26 22:37:35
