Hi, need a bit of advice. I've got a faulty PCB, I've just acquired a tl866ii reader and dumped the eproms. This is the first time I've used anything like this I hasten to add. I went online to try and find a way to verify if they were corrupted or not. I found a site with a drag and drop feature for the .bin files, I think it was' arid ' or something similar. I dropped 14 files in and all but 2 were recognized. The PCB was originally working many years ago but apparently got plugged in incorrectly and many people have dabbled with it down the years.
I guess getting to the point, is there a better site to check the eproms with ? As the PCB is working to a degree and coins up with sounds ok and game plays with horrendous sprite issues and tile mapping issues could the 2 unrecognized eproms be corrupted. Also being a novice would anyone be able to check the 2 .bin files if emailed ? They are listed as being CPU via their locations on the PCB and when either are removed the PCB will not boot. Not knowing the full history of attempted repairs I assume these are the original eproms but have read elsewhere that some versions of this board had an encrypted z80 and I believe the one on this PCB is just a standard Sharp one.
I currently am looking for some suitable eproms so that I can try burning various sets. The originals are a mix of Fujitsu mbm27128-25,mbm2764-25 and I didn't realize there's an Intel D2764-4 that is the sound eprom but I dumped it as a Fujitsu chip and the .bin files was recognized. Any advice/help would be appreciated in regards to a supplier of an appropriate replacement.
I'm pretty sure that the sprite issues are logic related,but I wanted to eliminate at the eproms from the tile mapping issues and determine whether or not they are for an encrypted z80 version.
