EPROM identification
bones
1,628CR
Hi, need a bit of advice. I've got a faulty PCB, I've just acquired a tl866ii reader and dumped the eproms. This is the first time I've used anything like this I hasten to add. I went online to try and find a way to verify if they were corrupted or not. I found a site with a drag and drop feature for the .bin files, I think it was' arid ' or something similar. I dropped 14 files in and all but 2 were recognized. The PCB was originally working many years ago but apparently got plugged in incorrectly and many people have dabbled with it down the years.
I guess getting to the point, is there a better site to check the eproms with ? As the PCB is working to a degree and coins up with sounds ok and game plays with horrendous sprite issues and tile mapping issues could the 2 unrecognized eproms be corrupted. Also being a novice would anyone be able to check the 2 .bin files if emailed ? They are listed as being CPU via their locations on the PCB and when either are removed the PCB will not boot. Not knowing the full history of attempted repairs I assume these are the original eproms but have read elsewhere that some versions of this board had an encrypted z80 and I believe the one on this PCB is just a standard Sharp one.
I currently am looking for some suitable eproms so that I can try burning various sets. The originals are a mix of Fujitsu mbm27128-25,mbm2764-25 and I didn't realize there's an Intel D2764-4 that is the sound eprom but I dumped it as a Fujitsu chip and the .bin files was recognized. Any advice/help would be appreciated in regards to a supplier of an appropriate replacement.
I'm pretty sure that the sprite issues are logic related,but I wanted to eliminate at the eproms from the tile mapping issues and determine whether or not they are for an encrypted z80 version.
7,230CR
The website version is out of date but the Roms may have not been dumped also. If the roms verify then you can prety much say they are good as you rarely get an intermittent rom. It will most probably be addressing / rams ect.
I can test your files you cant verify if you want ?? My software is bang up to date. Doubt it make a diff though romidents a good site.
TheDaddy2021-08-19 19:07:00
bones
1,628CR
Thanks, if you don't mind. The thing I used online gave about 6 different vaiations of the game for a majority of the chips, 2 or 3 had about 3 variations and the 7489 & 7490 weren't recognized at all so yeah it would be appreciated.
How's best to get the files to you and would it be better to send all 14 ?
7,230CR
Just zip and send the ones that dont work. With roms they may come up with multiple sets as there may be say 5 variations that use the same sprites rom ect. Most games are identified from the Cpu roms as these are more specific. The trick is to find the one that only brings uo one set and you can pretty much say that's the one you have.
7,230CR
So they all verify as good and I can identify the board as WBOY as 2 roms say they only fit one set.
EPR 109 & 116 register the same here (Both CPU's):-
The full set looks like this :-
Excuse the second image as the layout was never completed as only I use it so its all over the place !
Hope this helps.
