Hi All
I have recently purchased a TL866cs eprom programmer but i'm having a few problems, it works fine on checking standard logic chips and it will read eproms although the list seems of supported stuff is limited on the older 2716, i'm a novice when it comes to this stuff but here are a couple of pictures of what problem i am getting, firstly when trying to program a eprom I check to see if it is blank and if not erase under uv, then I check again if ok then I load up the rom file from mame, I am actually trying to burn a new defender rom 7, once loaded then program eprom it tries then gives up, on further inspection it appears that when you select the rom type it alters the voltages etc for you but looking at the older stuff they need 25v to program which this programmer doesn't go up to, so I have made an adapter and am now putting inn 25v on the vcc but I still cannot get it to program, I have also read that you can use a bigger eprom of which I have a couple and load the image many times until it is full, any pointers on how to use the eprom programmer would be greatly appreciated, if this is not fit for purpose I will go and buy another one that does older stuff!
Joe
Joe
