ESR on capacitors
Ronnie Dent
1,206CR
I have this tester which does ESR I removed a cap from an 30+ year old chassis it is 100uf 50v tester reports 103uf with ESR of .45 ohms so I get a new one 100uf 63v put it on the tester 99uf .64 ohms? so the new is worse than the old? what is considered high for ESR on a electo cap?
Thanks Ronnie
Muppz
362CR
Thanks Ronnie
The ESR varies dependant on material, value, voltage and if its a standard cap or low ESR. My meter has a grid printed on the front. For a 100uF 63v it reckons 0.3ohm is worst case for that value at 20degC.
However there seems to be some disagreement depending on where you look.
Always best to check the manufacturers spec sheet to see what a good ESR should be.
Muppz
andyJay
98CR
its not a chinese cap is it? they really are utter crap even if they state low esr/105C they never are up to scratch.
come across some weird ones in work "Jake" and "Hi" are my faves.
Ronnie Dent
1,206CR
Not sure to be honest I have a large amount of caps and just chuck new one's in figuring new will be better than old?
Ronnie
abaxas
124CR
TBH electrolytic caps are no something you should keep in stock.
They have a shelf life so are always better bought new.
obcd
3,830CR
ESR is most important on Switch mode power supplies. When the frequency of the ripple is higher (several khz to even mhz), the capacitor will heat up more. Due to that, it's expected lifetime will reduce. When I buy new replacement capacitors, I try to find those with a high expected lifetime. Some have a lifetime of 1000 hours, others of 5000 hours. This is mainly due to the fact that our machines run 14 hours/day.
Ronnie Dent
1,206CR
Thanks for the replies everyone, I must admit some capacitors I have had for many years! TBH I never thought they might go bad by not being used! it's always handy to have on hand a good selection of components.
I don't think anything I have will have a switch mode psu mostly linear
Ronnie
