explorer arcade
favouredson
Super Star
1,260CR
Are you sure you got that right?
The clock should be pulsing and the reset should be high during operation.
If you probe the reset on boot you should see it go low momentarily and then stay high.
Lurch666
4,511CR
Pin 6 should be clock and that should be pulsing.
Pin 26 should be reset which should briefly go low then high on turning the PCB on.
If pin 26 is pulsing then it could be watchdogging.
It's trying to run code,failing so the PCB is resetting itself constantly.
You would need to check the CPU roms and the CPU ram next. If memory serves that's the chips marked 0P,1P,2P and 3P for the CPU roms and the four 2114 ram chips at L3,L4,L5 and L6.
Lurch6662022-09-26 00:17:53
Shinydaz
814CR
You need a oscilloscope for rams really, if you have any spare, piggybacking sometimes gives you clues. Check output enables and chip enables on roms, and address/data activity. You need to check if the roms have correct data on them, if the rams checkout OK.
Lurch666
4,511CR
Pin 6 High means the CPU is not getting a clock signal.
The PCB should have an active clock otherwise you wouldn't see anything on the screen since the video circuit requires the clock to generate the display.
You now need to follow where the trace of pin 6 of the CPU goes and try and see where the clock signal comes from. You will probably find a chip that has a clock signal going into it but no clock signal going out and that will be the faulty one.
It doesn't help that there are no schematics for this board as far as I can remember.
favouredson
Super Star
1,260CR
Lurch666 said:
Just had a thought.
Is you CPU in the correct way round?
That's a good call.
If you look at the picture closely you can see that the two Z80s are inserted differently.
It appears to be the main Z80 that is back to front which would explain the wrong readings.
Lurch666
4,511CR
Just had a chance to check and you CPU does appear to be in the correct orientation.
Back to trying to figure out why you have no clock on your CPU.
Looking at the scramble schematics the CPU clock comes from an LS367 (4A on a scramble PCB) connected to the 1H signal which comes from an LS74 (7M on a scramble).
See of there's an LS367 near the CPU connected to pin 6.
Lurch666
4,511CR
Pin 8 of an LS04 is the inverted output from pin 9 so see if there's any activity on pin 9.
If there is then the chip could be faulty.
If not follow the trace to see what pin 9 is connected to.
