Yes demag demagnetising the screens - okay really need to do that if you’re having issues with the picture.
When the game is booting, but probably before the error you posted as that can hang the system, press test.
It will send you into test mode which has its own GUI and uses the test and service buttons - one to cycle the options and one to select. Have a poke around. You should familiarise yourself with all the options. Game settings can be used to set difficulty and there is a Grand Prix mode that switches the lap count to 16 for longer races.
Also set it to Free Play in the Coin Settings unless you want to use the coin mech.
The cabinet settings are in there. Set it to Single and then exit. It will reboot and if you’re lucky (really lucky) you will boot the game successfully.
As you’ve heard the speakers crackle and the wheel moved you could have a fully functional game - apart from one dead screen. As it’s not the middle one you will at least be able to have a go. Good luck.
