F355 Electrical Wiring
gr0don
110CR
Hi, So I have had this cab for about a year and not had much of a chance to get working on it. Finally getting around to it and was hoping someone could point me in the right direction for the wiring inside the cab.
I got the cab as a project. It has all of the plastics and controls as well as the transformer, CRT, untested MIDI drive board and a bunch of wiring. At the moment I am wanting to use the cab with a PC for emulating racing games and I have the correct FFB board from gamoover to hook the controls up to the PC.
I am going to make my own wiring for the controls so as not to hack up any of the existing wiring (I have the crimps and AMP connectors here).
My first priorities are: Get power to the CRT, get power to the MIDI drive board and get the MIDI board connected to the steering. The PC should be easy enough to wire up. I have attached a few photos to help out.
f355_trans&
What is that connector/fuse for on the orange/blue pair of wires and what voltage should I be expecting out of there? I am assuming one pair from that transformer should be 110 and one 240?
I assume the yellow wire that leads on to the pink and light blue wire is the connector that goes straight into the MIDI drive board at CN5? It looks like it should fit - I assume this board should be running at 110v?
To connect the drive board it looks like the thick gray cable connects CN4 on the drive board to the steering wheel and both of those connectors look like they match up - I just want to double check that before I do anything stupid.
I have not even powered the cab on to test voltages yet but hope to make a start this week. I am trying to get a clearer picture of how things are meant to be connected before making a start.
Thanks in advance for any help - hope it all makes sense. I have had a look at the service manual and although they are great for parts lists they don't really seem to cover the wiring in the cabs.
Gordon
8,288CR
Hi Gordon
Seems your missing a small
Fused Power distribution pcb,
838-11856-ce-02. At least it’s not in the photo.
This small fused 110v power distribution pcb takes the black amp up connectors which are containing the
Blue 100v& pink 100v Wires houses in the black amp up connectors.
The thicker pink &blue Wires, which are Connected to the yellow wires coming out of the secondary of the large
ISO transformer , which have a 7 pin connector take the power / connects to
this small fused distribution pcb that is not in the photos.
From there —-if your still with me. the black amp up 9 pin connector with only 1 pink and 1 blue wire this will also be connected to
The small power distribution pcb and connect to your midi servo motor driver pcb via a small capacitor pcb.
This link is for the f355 wiring diagram
All is contained with the schematic.
http://www.ukvac.com/forum/searching-f355-challenge-wiring-diagram-in-hd_topic364283.htmlRetroman8392022-06-06 19:18:15
Outrun2
Colonel Outrun
1,181CR
The fuse is probably on the 14VAC from the transformer to the amp, although they are usually purple/orange. Meter it to check.
There should be two taps off the transformer, 100VAC to the (missing) dist board which powers the CRT, drive boards, marquee lamp, PSU and sometimes the cab fans. The other ta is the 14VAC which only powers the amp.
Throughout the cab, pink and light blue will be 100VAC .
Are you sure you have a midi servo drive board? F355 had a drive board and a motor drive board like most other Model 3 drivers, only later games like iD1-3 and OutRun2 etc had the single midi servo drive board.
Outrun22022-06-06 18:40:06
gr0don
110CR
Thanks for the help so far guys.
I have ordered that fuse board from ebay and it should be here at the end of the week. I will take a look over that schematic - looks really helpful.
I think the drive board is from a OR2 cab, I got it separately as the F355 ones were harder to find, part of my thinking was if I ever wanted to change the cab away from emulation I would rather go down the OR2 route than F355. Most of the artwork is missing/badly damaged anyway.
Will no doubt post back soon when I get stuck again!
Thanks,
Gordon.
8,288CR
I’m looking to do the same.
I have the l2m2 pcb.
And a touring cab..
And I have since bought a Daytona full dash so I have the
Correct ffb steering motor ..
So I’m paying Close attention as I will need to do this as soon as I have created enough space to work in!
chris2922
333CR
Gordon, the FFB board you got from the French lot, did you get the “F355 hack” and the FFB board? Or just the FFB board? I got both but unhelpfully it came with no guide or explanation at all!
gr0don
110CR
I will keep the thread updated with my progress. I have also been working on a front end using Attract Mode. It is optimized for driving cabs with 4:3 displays as I could not see anything off the shelf that worked well for that.
Chris, This is the board I have, what do you have?
chris2922
333CR
Same board but I also have a daughter board that sits between it and the F355 looms so I don’t have to cut/chop any connectors. I’ll add a picture to this post when I get back later.
