Faulty PS4 - worth it?
Purity
The Oracle
17 (100%)
2,999CR
I've been offered a faulty PS4 with a broken bluray drive for less than a third of the price of a normal PS4. No controller though
Apparently the previous owners child forced a bluray in the drive and a bit
snapped off inside. Not the bluray but a piece of plastic somewhere in
the drive
Now is it worth buying?
I realise that the bluray is married to the console, but the bluray pcb will probably be ok, and might be transferable in future?
No idea if the laser is damaged either
Obviously digital content would still work but not anything from the drive, until it is sorted - if it can be
I have no idea of the extent of the damage until I buy it and open up the drive
What do you guys think?
Also I believe he has spoken to Sony and admitted the damage so, using warranty is out of the question
Purity2014-02-04 19:20:47
Ace`
PlanB contributor #1
36 (100%)
3,763CR
I'd go for it as long as the security sticker is still intact so you know they haven't broken the system beyond repair. Sounds like it should be quite an easy fix or like you say a simple drive swap in the future.
4,055CR
Equites said:
I would definitely go for it, don't forget all games are available as digital download as well as physical disk.
I still say go for it, but have you seen the prices of digital downloads
If you buy digital downloads only you'll have spent what you saved on the console in no time. I honestly don't know how Sony expect to sell any digital downloads at those prices.
Purity
The Oracle
17 (100%)
2,999CR
ZedEx48K said:
surely the 'piece of plastic' is findable and glue-able?
Exactly what I thought. It might be glue-able. It depends on how bad it is and what the part actually does. Again, without opening and looking I am purely guessing
With it being loose inside it *might* have damaged the laser also, but I suspect it might be possible to get replacements
Purity2014-02-05 10:45:02
samusaran
249CR
I agree.i really wanted to go digital this time but the greedy gits never learn.they would sell triple the amount if they lowered the price.a win win situation for everybody.
4,055CR
Lower £40's if you've got the patience of a saint and the nose of a bloodhound. More like £50 - £55 if your Mrs decides on a Saturday afternoon that she want's to play two player Knack and the only place around is Argos!
[EDIT] Controllers are overpriced too! What was wrong with charging £30???
guddler2014-02-05 18:51:54
Purity
The Oracle
17 (100%)
2,999CR
Good news and bad news.
Good news. I've taken the PS4 apart and found the loose part and removed it. The part doesn't look like it has snapped off
Bad news. For the life of me I cannot find the location of where this part goes. It's labelled as "F2-14". It clearly goes somewhere, but I'm just not sure where. It has grooves in it, so it must slot in somewhere. I don't expect Sony will help me with this one
The problem I have is not many people have cracked these drives open, due to them being brand new, so I'm a bit stuck
Purity2014-03-03 23:23:59
silverfox0786
Beware the Hillman
47 (100%)
2,699CR
your first mistake was opening it
if the security sticker was intact i would have called sony direct
they offer warranty replacements with out seeing an original recipt
i have swapped more PS3s that way then i care to remember
ZedEx48K
8-Bit
1,365CR
That be why!
You could try looking for a PS4 tear down website or video and see if you get lucky spotting the part.
Purity
The Oracle
17 (100%)
2,999CR
The warranty was already invalid, as the previous owner had admitted to Sony that he caused the damage.
They wanted £175 to replace it with a refurb unit, so that is how I ended up with it.
I bought it knowing that.
Purity
The Oracle
17 (100%)
2,999CR
ZedEx48K said:
That be why!
Correct :)
I know I can fix this.
I have looked at all the teardown images/videos I can find.
The only images I've found is where someone changes the laser on the unit. I've studied those images and I still cannot see where this part goes.
I shall persevere. I'm sure I'll get there. Then I'll post this stuff up for other people with bluray PS4 issues
4,055CR
I guess not? Surely that's too obvious!
I wouldn't want to risk a game disk to try it in case it spins out of control but a cheap DVD maybe.
Purity
The Oracle
17 (100%)
2,999CR
I've just found a video with someone that has the same issue, but it looks like they don't know either, and I can't understand what they are saying
It looks like they leave the part out and the drive still functions, so maybe worth doing that
Purity2014-03-04 11:05:51
Beaps
349CR
I was gonna say, in its open state, can you not try and insert a disc any you may see something like an leaver not being pulled it might give you an idea.
