Fightcade
LewisGamer
97CR
Anyone had any experience setting up fightcade to run through your arcade cabinet?
I’m guessing it may be possible to use a dual screen setup where the lobby is displayed on a second monitor, and the game runs on the arcade monitor.
Lewis
trev1976
171CR
Hi
No I run it all through my MS8 CRT in my Aero City. Once the drivers were set up it was all quite straight forward. Just adjust the settings on the emulator in fightcade for proper low res and adjust a couple of the settings so you don't get screen tear and it will look fantastic.
pubjoe
880CR
I used to do this with CRTEmudriver when it was GGPO. I never tried setting up dual screen. I always thought it'd be great to have a 15k and joystick friendly ui.
eliotcole
1,156CR
Well, you can easily do that with a GPU on a machine running an emulator as long as at least one of the GPUs of the machine has an analogue output. (I know that you can convert digital outputs, but it'd be preferable for the machine to render analogue directly, for me)
Essentially, if it's all over one GPU, then you're golden, but if you're using two, and one is more powerful, then you may wish to render on that, and output on the weaker GPU that has analogue output. 🙂
I understand that it's simplicity itself in Windows, however I've never been able to figure it out on Linux, because the searches involved just end up with a mountain of frickin' virtual machine nonsense. That being said, I've read a couple of things about 'prime' or something ... but I have no idea if that's an NVidia specific thing, or something to do with the operating system, whether it's still true with newer, Wayland compositors, etc, etc, etc ... anyway ... yeah ... it's a thing that is possible, for sure, and if not the option that some might take is certainly the route that I would take for the best possible output.
pubjoe
880CR
Every time I try and do something in Linux I give myself a headache searching through ever changing syntax and multiple ways to unachieve. My 14 year old is much better with it than me.
Would it be so bad to make a windows install on a small SSD dedicated to this purpose? As you say it's simple that way.
eliotcole
1,156CR
Yeah, I hear you ... my (ironically non-combative) counter is that literally everything I've done with Linux in the past 4 years just ... works. Plus ... it doesn't just ... DECIDE ... that today it's outputting to this HDMI instead of the usual one ... or taking mic input from that microphone ... etc etc ... I got so frustrated with Windows just not doing what I wanted that I could not rely on it. For something that I'd like to be 'turn it on and go' I'd rather have something that I can rely upon ... so ... for myself ... that'll be Linux ... and probably Debian for simplicity's sakes.
That being said, my response was not predicating that anything had to be linux ... I was actually just saying that it's the place where I *don't* know how to do what I'd like to do, here. So, more power to whomever in doing this in Windows with a second GPU ... I mean ... that whole 'two GPU thing' isn't even necessary, as (like I said) one can also just ... slap a converter on a digital output.
Either way ... I've got Fightcade running on Linux right now and it's lovely enough ... still not quite perfect ... plus my biggest frustration is that the whole platform relies on electron (chromium based) code ... and I believe has some aye eye involvement ... ... But ... yeah ... ... I dye cress ... if this thing had a secondary GPU ... then I'm sure that I'd find a way.
