First attempt at eagle
Ace`
PlanB contributor #1
40 (100%)
4,040CR
I've wanted to learn eagle for a while now as there are a few pcbs I'd like to have made rather than just making them on prototype board. I probably should have started with something more simple but I've attempted to make the boardmaster 4000 4116 adapter that was posted here http://www.ukvac.com/forum/abi-b4k-test-basic_topic339944.html
I've uploaded the files here https://www.ukvac.com/forum/data/uploads/741/4116_v2.rar
if anyone is up for checking them for me, for either mistakes or improvements I'd really appreciate it.
This is actually my second attempt as I later found the name links way of joining pins is a lot neater and easier than just joining everything with net lines.
I also used autorouter which might be a no no? I used eagle 7.6.0 if that matters
Ace`
40 (100%)
4,040CR
All the problems? that doesn't sound good
If you could fix it that would be great but if you could list the problems too so I don't make the same mistakes again I'd appreciate it, thanks.
silverfox0786
Beware the Hillman
47 (100%)
2,699CR
yeah i'll fix it, but clicking on link i couldn't find schematics to actually check that part
board side of it was a silly mistake really, you didn't set your DRC check parameter nor your Net classes. setting those would have prevented you getting the errors i have found
also you header i assume is what sits in the Boardmaster socket so should be a pin header and the ZIF, will that be a ZIF socket or a DIL socket?
