I'm no expert but will try and give some advice as I have just bought my first pin
go and play as many pinball machines as you can so you can work out which games you like everyone's taste is different
eg I don't like Adams family ,or attack from mars but everyone else seems to love them
I like data east hook but no one else dose
electric circus or tilt in Birmingham are good and have a mixture of all tables from different manufacturers and years
pinfest is soon also
I was warned not to buy gottlieb machines as they are harder to fix and parts are expensive or hard to find
I was also warned away from electro mechanical machines because they are hard to repair I don't like how slow they play anyway
For a first pin
I would go for something solid state from bally or Williams as most of the fixes for stuff are well documented
you need to be fairly handy with a soldering iorn but no different to repairing arcade boards / monitors really
Recapping ect
any pins you are looking at check playfield wear and broken ramps and plastics as some are not reproduced and are unobtainable unless some one breaks a pin for spares
Playfields that are worn out down to the wòod or have planking unless really cheap arnt worth bothering with home
Repair and touchup without it looking s**t
Is hard unless you have an artist in the family
cheapest projects I have seen start at around £500 upwards if you have more money the dot matrix stuff is available
I have been lucky with my pin its been quite an easy project so far
probably a bit too easy tbh
but I have still had to put a couple of hundred into it
and still have stuff to do to it
Fun when you have a nice working game though
robotech2018-07-14 04:37:47
