First Taito cocktail table issues
gazcicini
18CR
Hi all finally got my first Taito Cocktail think its a space invaders 2 one comes with a 60-1 and 1942 with jamma loom. Its generally in very good nick although I will be changing glass and getting legs re-chromed in future. It has 2 hopefully minor issues the first is the volume it is high and I dont know how to adjust it I was aware when I bought it so hopefully it is fairly easy.When I power up the screen is displaying twice if that makes sense ie I can see 2 of the same images in the horizontal. It reminds me of tuning an old tv and I am hoping it is a simple as that as I am dying to get playing. Can anyone offer any guidance also I am aware that the monitors are high voltage so i take it its bad practice to have powered up with the lid open?
Thanks for any advice just want to get playing.
Gaz
gazcicini
18CR
Just a note the screen seems to have settled down now I think the journey may have upset it. Also unplugged the speaker so I can now play it. With regards to sound is this controlled via dip switches on the boards or would I be able to wire a volume control into the speaker cable? Any help on that would be appreciated. Photos posted soon.
Turns out the 1942 is actually "Legendary Wings" which unfortunately isn't suitable for a cocktail and seems to be a 2 player/2 button stand up so that may be up for swaps for more cocktaily boards/art/items of interest stuff if anybody is interested.
gazcicini
18CR
Thanks for responses only had speaker plugged in with 60-1 to keen to play to worry about. Will try the proper pcb tomorrow. As for boot or original I have no idea but if there is a way to identify let me know and I'll check out.
gazcicini
18CR
Looking over the interweb the sound loudness issue points to the 60-1 board as not being very good with its emulation. So may have a word with electrical guys at work about placing in a volume controller in the speaker positive run as there is an RS plug for disconnection so thinking placing there so I dont cut any cable.
gazcicini
18CR
Still having screen issued. The 'original' wings PCB works fine sound and video wise unfortunatly its 2 button so cant get much use out of it. The 60-1 rolls when plugged in sometimes is there an easy adjustment for this, ie: Vertical hold I can try safely. Any help would be appreciated.
P-Man
International man of mystery
1,273CR
Have you actually found the volume pot on the 60-in-1 ? its near the vga connector, and black heatsink, its small and orange.
Also, 1942 is a dual layer pcb, and no, there isn't a big black chip with Capcom printed on it, there is a serial sticker that can be various applied to somewhere on the top pcb (sometimes its put onto one of the various 40 pin chips on there)
The top pcb should be silk-screened in white with the Capcom logo surrounded in a box...
a phots answers a thousand questions.
gazcicini
18CR
I have found the volume searching google earlier today. Dont have BBand at home at the mo just phone. Its the monitor pots I am going to try and find this evening to get the screen working with the 60-1. The dual layer PCB thought to be 1942 turned out to be a bootleg Legendary Wings which runs thing except teh absence of the 2nd button but nice to see things working with all old parts as opposed to the 60-1. If anything it seems to operate better in terms of screen and volume. Need to increase the PCB count now.
Thanks for pointers.
ssppllaatt
9CR
Forgive me if you already know this or someone else has said it already but on my 60 in 1 the sound is adjusted by (with the machine switched off) setting jumper 4 to the up position and going through the menu system (its near the end after the game settings) I have mine set to just 3 (out of 50 i think). As for picture - you have got the jumper correctly for your monitor (not set for VGA). Just some thoughts.
gazcicini
18CR
Hi ss thanks for that but have adjusted by board pot. I cannot use the board menu yet as only one button so cannot change options. Next step is to buy a few and solder onto jamma loom and leave inside machine so I can adjust settings ie turn to cocktail mode, delete some games, and turn of the annoying menu music
