Fixed : Star Wars 1/2 screen problem
48CR
My starwars cockpit has just started playing up. The screen only seems to be being drawn on the lower half?
Any ideas on where to start?
thanks
silversmurfer2013-01-06 19:36:46
5,653CR
dead/dry joint transistors. If they are dry joints you can normally palm whack the side of the cab and it should jump in and out of full deflection and the collapse.
48CR
Thanks for the quick reponses guys - as it's christmas eve now it'll be a few days before I can check. I did a percussive maintenance test but it didnt change!
Will open her up in a few days and report back what I find.
Re monitor type - not sure will check this while I'm there !
thanks again
Nik
Level42
212CR
My bet: WG 6100.
This is a pretty rare problem on Amplifones.
WG6100 have lots of contact problems around the deflection transistor connectors on the PCB. I once had a hair crack between on the track between the solder eye (island we call it) and the rest of the track. I had reflowed all the connector pins without any success but only after I metered out all the tracks I discovered the problem. Bypassing the crack with a piece of wire was the answer...
Level422012-12-25 08:30:49
48CR
ok folks I managed to get round the back and take a look !
at the deflection board
I did notice a dodgy joint on c100
Not sure why this is bridged like this - should it be?
anyway I reflowed the pad and it didnt solve the collapse issue :(
Are these the deflection transistors I should be looking at ? these seem to be chassis mounted ? I did notice some other transistors on the deflection board itself ..
andyman
1,059CR
That's the ones, check the transistors and the sockets (dodgy connection between transistor pins and the sockets is normal) and the molex connectors/pins on the deflection board, reflow pins if needed.
P-Man
International man of mystery
1,273CR
Q102 - Q103 are your Y-deflection chassis transistors, your issue is related to Q102 (2N3716) these are mounted to the flat base of the monitor, the ones visible between the deflection board and the hv cage, not the ones under it.
There is an oustide chance it is Q100 on the deflection pcb itself, but you must check Q102 on the chassis first.
Check for cold solder joints on the underside of connectors P100 and P700 on the deflection board.
A very quick way to see if Q102 is your issue is to plug connector P100 into P700 and vice versa. If you lose the right hand side of your screen, but get deflection to the top of your tube then your culprit is definitely Q102 or the connection to it.
48CR
ok swapped p100 and p700 around made no difference issue still with only lower half of screen being displayed ( all across X axis). So does this look like Q100 ?
Armed with a multimeter then how do I test ?
thanks for your help so far
Equites
Chief Sheesher®
35 (100%)
3,329CR
Have you re-flowed the solder on all the header pins on the deflection board? If not do so.
edwoodjnr
246CR
Same as what P-Man said, you need to read this guide...
http://arcarc.xmission.com/PDF_Monitors/FAQ%20Wells%20Gardner%206100%20Version%201.0%20dated%201%20Mar%2002.pdf
See page 25 about the chassis transistors and the symptoms of when they go bad - i.e. half screen displayed.
Gavin
48CR
Going by the above pdf - thanks very informative ! I did the meter test on the chassis transistors and Q605 seems to be suspect, leads / pins buzz out ok but no drop is observed. Compared this to Q102 and voltage drops where seen as expected
Q605 connects into P600 (?) so is it still possible to do a swap test and if so with which P100 or P700?
If it is indeed Q605 then is there any preference for a replacement ? seems a bit of a price difference!
2N3716 - £4.97
http://uk.farnell.com/jsp/search/productdetail.jsp?sku=1208626
NTE284 -£17.12
http://uk.farnell.com/nte-electronics/nte284/bipolar-transistor-npn-180v-16a/dp/1383730?Ntt=NTE284
48CR
Thanks for all your help guys - she's now back and the force is strong once more !
See the text below after the picture for my full repair story this week !!!
Ok I previously identified that Q605 was bad so I ordered a new set of both types of chassis transistors just to be sure !
I replaced Q605 - turned the machine back on but now only a picture in the lower left 1/4 of the screen.
then horror, a smell of burning !!! quick turn the machine off and figure out what happened..?
R100 was fried on the deflection board :( further investigation revealed a newbie error. When I replaced Q605 I didn't check for continuity! Q605 was shorted to the chassis :(
The monitor was now not even showing a picture but the game played blind - looks like no neck glow / no voltage ooh err !
Ok so I replaced Q100 and using a printout of the P314 board as a ticksheet I check the diodes, resistors, fuses, connectors and anything else I could prod with my meter to make sure things were good as well as reflowing the solder joints.
Once I was happy(ish) with the board I then double checked all the chassis transistors again. I created a ticklist so I could check each transistor for voltage drops from the correct pins, connectivity to the headers and for any shorts to the chassis.
Q102 was also showing a problem so I replaced this. Once I was happy with my ticksheets I plugged everything back and up she came ! Yeah !
So what have I learned ..
1) My delfection board seems to have been repaired / upgraded several times - so only bears a passing resemblence at times to the online diagrams / manuals etc.
2) not to try and rush things, my ticklists helped my focus my diagnostic approach and forced me not to randomly try things but to work in a methodical manner
3) there is a massive amount of information out there especially on forums such as this and KLOV. Without your help I'd have a big doorstop !
4) I'm sure this was a relatively simple repair in the grand scheme of things but it does make it worthwhile when you are able to get something working once more.
I've read about an LV2000 (lite) board so I may give this ago later on.
Once again thanks very much for everyones help !
DanP
Administrator
2,232CR
Great work and thanks for reporting back. I like the idea of the ticklists, I need to do some of that in future I think!
Dan
