Fixing power supplies?
JohnnyChaos
Blows own trumpet for CHQ cabs
325CR
I've got two dead jamma PSUs. Power goes in, but nothing comes out. Doesn't blow the fuse either.
I gather it's usually the rectifier diodes. I started unsoldering them to test and one touched the other and "crack"
I never knew these things held a charge?!?
Are they likely to be fried now?
And are there any tests I can do on stuff like this in circuit or does it all need desoldering... At least one leg?
trm
2,877CR
Hi dude,
I suspect it was the capacitors that were holding a charge that you then shorted. Better through a diode than your fingers!
For the diodes you should be good to test them like a resistor (but on diode check obviously) by unsoldering one leg and measuring them.
P-Man
International man of mystery
1,273CR
I wouldn't say that the diodes are the main cause of failure in switchers at all. But then again, because a brand new power supply is £19, nobody bothers to fix them, its usually more involved, somewhere with the chopper transistor or the regulation.
Sorry Tim, a diode tests like a diode, nothing like a resistor.
Remove all power from the unit. Set your meter to diode check, lift one leg of said diode out of circuit and put your leads across it, you'll see a junction voltage reading of between 0.5 and 0.8 when your leads are black to cathode, red to anode. Then reverse your leads, you should get no reading. If so, then all is well. If you read 1.2 or anything outside of the 0.5 to 0.8 range then you are looking at a fault.
trm
2,877CR
Hi dude,
My English was ungood. I meant in the way that you measure a resistor by lifting one leg, you should do the same to measure a diode using the diode check function.
Me fail English? That's unpossible!
