Flat screen for max tune
cr5000462
2CR
Hi, can anyone recommend a good led screen that will fit a max tune cab without having to modify the cab?
It's for a Pc conversion so the screen quality is important
Fantazia2
2,246CR
I think the max size you could fit without modifying the bezel would be 24" Widescreen, with it being flat should be fairly easy to get a piece of plexi to fit and then mask off the parts that the screen doesnt fill.
If you woud prefer a 4:3 option then other solution would be to remove the speakers and mount something like a 32" screen behind the bezel, that should come closer to filling the 4:3 shaped hole with the extra bits of the screen hidden behind side of the bezel, you would then have to come up with an option for speakers though, and you may need to trim the back of the bezel to get the screen as close as you can, cant remember how deep the speaker mountings are.
Fantazia22020-08-14 12:43:44
cr5000462
2CR
Thanks, I didn't really think about the gap around the screen.
Reason I wanted flat screen is due to the Image quality when running a Pc on 4k settings, any other ideas to fill the whole screen area?
