Fluke 9010A Internal/External storage
brianj
1CR
I was watching Jerry Walker's videos about his new memory device that replaces the tape drive in the Fluke 9010A. I finally realized why I couldn't get any of my circuits working - thanks Jerry! So, I started to think about building a replacement for the RS232 card when it occurred to me - you just need an ESP8266/32 to RS232 converter and you are set! Then of course I found out there are tons of these things around - but no software specifically for the Fluke. So, I started trying some things and here is what I came up with - just trying to see if there is any interest. I really just have to tweak some existing software and away we go!
RS232 -> ESP8266/32 (would add Bluetooth access): http://subethasoftware.com/2018/02/28/wire-up-your-own-rs-232-wifi-modem-for-under-10-using-esp8266-and-zimodem-firmware/
Wireless access to fluke from FIDE - no USB/RS232 cable needed
SD card to save/load programs from
OR no SD card needed - load files from Phone, Table, PC to RAM on adaptor
Wireless access to "console" in a web page - could use PC, Tablet or Phone
Pretty much the same hardware as: https://electronicsisfun.com/f/gurumodem--the-gold-standard-in-rs-232-wifi-communications
This option is pretty easy. Just need to tweak some existing software. The software for the pre-made hardware above is a modem emulator, so it really doesn't work in this situation.
This software: https://github.com/jeelabs/esp-link does a lot! You can connect from FIDE to it using a telnet to serial program like: https://sourceforge.net/projects/com0com/
You can open a console on your Phone or Tablet also. Still not Fluke specific but close!
ESP8266/32 daughterboard for Piero's card
Would all be internal - would connect to location for MAX232
Maybe SD card sticks out back
For the above
Options:
OLED screen
Pushbutton(s) to be able to select file to upload/download
My initial test was just 1 file on SD card, push button and it sends it.
Compile in system (maybe remotely via FIDE) or make compiler to run on ESP and/or PSoC
Terminal: https://geoffg.net/terminal.html and derivatives
VGA and/or composite output
PS/2 or USB keyboard input
by itself or in addition to above
New Internal card
With 1 or all of above internal
Maybe use PSoC to emulate UART
Some hardware already exists (see above) - mostly it would be patching things together and making them
work for the Fluke specifically.
brianj2020-10-29 22:49:07
