Fluke 9010a - UUT Power Fail
alfa75
19 (100%)
96CR
Could someone explain what this error message mean and how I can fix it? Thanks!
DanP
Administrator
2,232CR
It's saying that the Unit Under Test (UUT) doesn't have the correct power going into it to allow the Fluke/Pod to run the board. How are you powering the PCB you're attempting to run?
alfa75
19 (100%)
96CR
I haven't attached a pod/board yet, which means that this is normal in this state? I only changed the voltage from 110V to 240V and didn't know if I had done anything wrong.
DanP
Administrator
2,232CR
Did you press the "RUN UUT" button? On power on it shouldn't say that, it should just say "READY" but it would say that if you pressed that button.
alfa75
19 (100%)
96CR
Yes I had pressed the RUN UUT button, which means this is normal. On startup it has the message READY. Thanks for the information and sorry for the beginners question!
alfa75
19 (100%)
96CR
Thanks for the link, I'll read it in. The whole thing is still new territory for me and since the devices (especially the pods) are not very cheap, I don't want to do anything wrong.
Ulrich
