fuse advice needed
big10p
Coins detected in pocket!
6,093CR
A fuse has blown (as in completely exploded) on the mains inlet to my cab. The inlet unit has an on/off switch and what looks like a built in mains filter, too. There's a sticker next to it that says "3.15A 250vac", so I need a 3.15 amp fuse, right?
The fuses are the smaller 20mm ones. I have some 3.15 amp ones, but they're anti surge type. Will these do, or do I need 'fast blow' ones?
Sorry for what are probably dumb questions, but I just want to make sure I get this right.
Ace`
PlanB contributor #1
40 (100%)
4,040CR
The fuses you have will be fine, if it doesn't blow fast enough there's a fuse in the power supply and monitor chassis anyway.
obcd
3,830CR
If it really has exploded, your new installed one will likely explode as well. If fuses blow, it's usually for a reason. You might have a short somewhere like in the input filter, the monitor chassis or the game board power supply. (Unless you created a short yourself so you know it's gone)
big10p
6,093CR
I was all my fault. I was testing the de-cased marquee LED light strip, to try and find out why it keeps failing. It takes 240v as input. I took care to make sure I didn't go near any exposed contacts, but it slipped and shorted on the monitor frame. Bang! Flash!
Turns out the fault with the LED strip is IT'S CHEAP CHINESE CRAP! Who knew?!
Cheers guys.
bomjac
453CR
12 v led strip buddy. Take a 450mm length and stick it in the light area. Tap the 12v directly from the PSU and jobs a good un.
Have a search for sinistar with bomjac as the poster and you'll find a thread (maybe 2yr+ in age).bomjac2017-03-22 03:38:37
big10p
6,093CR
It was just more convenient to use the mains powered one in this non-JAMMA cab. Used them before and they're great. Just this particular make/model is sh!t. I've got some 12v strips somewhere, so will probably use those.
obcd
3,830CR
At work, we replaced some EL tubes by led equivalents. No idea how they do it, but the tube lights up equally over it's entire length. So, no problem that you see the individual led spots if the marquee isn't very dark. The tube is not transparant but white like a normal EL tube.
big10p
6,093CR
Yes, that's like the ones I have. They have a tubular lens cover that looks like an EL tube, which does a great job of diffusing the LED light.
