Plea for advice from the monitor experts out there....
I have one final issue with the Electrohome G07 19" monitor in my centipede which is really "bugging" me.
I got the cab playing blind, and basically shotgunned the chassis, gave it a full cap kit and fitted a new flyback to it and replaced the blown fuse with a socketed new fuse, which brought it back to life, with really quite a nice picture, despite a little screen burn.
A problem still existed with it though, in that adjusting the Horizontal Width coil did absolutely nothing, and I have about an inch at the top and bottom of the screen unused. The coil had black goo on the outside of it, so I presumed it was dud and ordered a new one.
This week I got sick of a dry joint that was causing the sync to go if the fire button was pressed a little too aggressively, so I whipped out the chassis and sorted that (it was on the video input connector pins) , so while it was out I fitted the new width coil.
Now its all back in, I find that the new width coil still makes no adjustment whatsoever, and worse still, I have lost a further 1/4 inch of screen use top and bottom. This means that I now actually see some screen burn when playing, which is annoying.
Any ideas what I should be looking at when I next remove the monitor from the cab ?
