GadgetFreak Conversion Help !!
TheDaddy
14 (93%)
7,230CR
Hi Guys / Gals. I have a few Pang 3 boards I decided to convert over the weekend as I cant stand the game ! SO I started with :-
Ghouls'n Ghosts - Converted the board and using the Ghoulsu Rom with Board B ticket - Burned all of the Roms and inserted them into the board ( Split ROM01 & ROM07 and burned using 4096 on tl866 with adapter ). When I powered it does the checks and the beginning and then I get a blank screen with nothing at all. Sometimes the audio with run but screen blank and not playing blind. I burned a new full set of roms and tested but get the same. I thought this may be the PCB as I had nothing to test to see everything was ok.
After this fail I grabbed a different B board and decided to try Mega Twins - Converted the new B board and burned all the Roms as per instructions. Placed them in a fired it up and it does work work I have no FX audio - I get background audio fine but no FX. There is some issues with the background on the title screen (I will post images when I get 5 minutes). The game plays fine and ingame graphics are absolutely fine as far as I can tell.
At this point I thought I must be doing something wrong or I had 2 faulty boards some how. I swopped roms from one board to the other and get the same result and also changed the C boards as I had no way of knowing if these were good - But again as far as I am aware the C would not effect the audio anyways. I also as burned a new set of roms for Mega Twins just to try and same result. I have also taken all chips and check and verified all of them several times and cant find any issues with the roms.
I then decided to try another game as there was 3 games I wanted to play. I burned 1941 Counter Strike doing the exact same thing as before and this works fine on both B boards I have converted - All audio and video. The only difference I can see is that the GFX roms are 27c160 Not 27C322 like Ghouls and Mega twins. I have now confirmed all of the C boards I am using are working OK as well.
Any ideas what I am doing wrong ????
Thanks In Advance,
Dave.
P.S I am going to convert the 3rd board at some point just incase I have 2 board with same fault.
TheDaddy2020-04-27 09:36:04
SUPERSPRINT
1,035CR
are you sure that you can convert these to gng? As far as I was aware the only game suitable for 100% conversion was sf2 champ japan version. You’ll need a gal chip also for that.
TheDaddy
14 (93%)
7,230CR
Thanks for your reply mate , Yeh these are the Mitchell Pang 3 boards - Not original ones as such. I was hoping to have :-
1) 1941 - Working
2) G & G (Cant get to work)
3) Mega Twins (Cant get this to work)
Dave.
Layer
376CR
Mitchell Pang 3 B-board may have a different layout than Capcom ones. So you'll have to make a proper pal to remap sprites, scroll 1, 2 and 3 ranges.
You have all the info about pal, banks, sprites, scroll 1 to 3 at the end of MAME cps1.cpp video driver.
TheDaddy
14 (93%)
7,230CR
Using Gadget freaks tool that allows you to convert the pang 3 board into a different games. Pal chips and board modifications have to be made.
Dave.
