Hey Mark,
Is that the same galaxian boot you got from me a few weeks back ? If it is i had the same fault with it last year, I can't quite remember which ttl was at fault but have a look at the 2 socketed chips at 6R and 4D, Although 6R could be sound related, It developed 2 faults over the time i had it, colour fault and a sound fault so i forget which was which but one could have failed again.
Failing that probe the other socketed ttl's as it's a fault that's been repaired before so it should give you a few leads, The original schems are pretty much spot on for that boot so should be fairly east to find with a bit of head scratching!
