Galaxian missing 'dive' sound
karlcdoe
887CR
Hi,
Can anybody enlighen me as to where the dive/swoop sound originates from on a galaxian board? I've had a poke around the board and also Mr Macros tips at
http://www.arcades.plus.com/galaxianfix.htm
and I assume it's actually generated in the 'tunes' section chips at 9J, 8K, 9K, 6T, 6R? Thing is that all the other sound effects work. I've also been able to test most of the other effects with the help of the schematics by toggling the relevant chip legs on 9L basically by dropping 5v across them. I can turn most/all of them on/off this way but I can find or activate the dive sound. anyway, here's a video that might demonstrate
Missing sound
One thing to note is this board has some super hard game rom hack 'super galactic wars' on it so I did wonder if it might have been disabled in the software? Surely I should still be able to set the effect off by probing the right chip though?
Anyway, there a very minor GFX glitch as well on the score table that I've included just in case it's related
Probably unrelated minor gfx glitch
Any help appreciated.
Karl.
DanP
Administrator
2,232CR
I think it's defo one of the IC's you've listed Karl. Have you seen the Galaxian Troubleshooting manuals 1 and 2? I had a quick squint and they point to where you're looking. I'd be tempted to socket 9J, 9K, and 8K and go from there.
Dan
karlcdoe
887CR
I'm pretty sure I looked at the outputs of the 161 counters at 9K/8K with the old HP logic clip and (I think) they were all doing 'something', I kind of assumed a stuck bit here would alter all the sound effects that use that stage but I didn't try that theory out. I guess I could see if I have any spares lying around and try the comparitor or socket/replace them. Same goes for 9J.
Oh yes, I have already found the troubleshooting guides thanks, they do point to a similar area of the board but I wasn't entirely convinced any of the sound symptoms were a direct match so back to trial and error.
K
karlcdoe2011-01-18 17:19:22
favouredson
Super Star
1,260CR
karlcdoe said:
......I wasn't entirely convinced any of the sound symptoms were a direct match......
Don't forget that the trouble shooting guide states that the effect listed is with the IC removed from the circuit. A faulty IC still in circuit could easily give different results.
karlcdoe
887CR
Ha. I didn't read the troubleshooting guides closely enough to realise the readings were with the chips removed. As regards the clocks, I know I checked that there was a clock present but I didn't bother working out if it was the right frequency. I'm wondering whether I should get the ROMs reverted to the standard game. I mean, are these hacks actually any fun? I had a few games on it and it just seemed a bit intense.
Macro
2,016CR
check for signal into 6T pin 13, thats the tune out from the 161's etc. it is then output from that on pins 8,9 & 11 and switched via the 4066 into resistor chains to control the volume.
if you get the other noises, then after that should be fine!
karlcdoe
887CR
Hi,
I'm not seeing any activity on pin 13 of 6T when the 'dive' sound should be playing, although I do for other 'tunes' such as coin up and the start jingle.
I've checked for a clock on the 161's at 8K and 9K and pin 2 of each is around 1.5MHz. I've stuck a logic comparator on both the 161's and it's not flagging any problems.
I have tried piggy backing a new 273 on top of 9J with no effect. I guess my next move will be to soclet and replace the 273 at 9J.....
K
Macro
2,016CR
actually, I wouldn't bother - that circuit must be working fine for the other tunes to work.
the main bit left to check it what you suggested in the first post - maybe the software hacked that for some reason. can you dump the roms and try them in Mame to see ? (or just stick it back to galaxian normal)
mind you, that graphic glitch it odd as well - I had a similar problem on a PCB and it was down one of the video block signals being wrong - there's a signal that prevents writes to video ram whilst it sorts out the sprite drawing, and on one PCB this was not there - whilst it draws the sprites, it muchs about with the address bus in that part of the circuit, so if the program writes to video ram, it ends up in the wrong place - looked like 0 and P1 being written behind the sprite!
from the repair log ...
[font="Arial, Arial, Helvetica"]This one passed the memory test on bootup (most of the time),
but consistently missed out certain letters on the screen display. Even odder,
the missing letters seemed to sometimes appear on the top line of the screen.
Phil had already replaced pretty much every chip to do with address decode,
buffering and selection, but it still had the same problem. Using the 'video
probe' (as mentioned in the Galaxian troubleshooting guide) I looked at the
various signals used to control the video memory lockout. CMP BLANK is used to
control the address selection to the 2114's, and that looked fine, VBLANK
(used in the vram control) also looked normal. The only signal that looked
slighty odd was HBLANK - I compared this against a working board and it looked
to be enabled for about 8 pixels longer - this reduced the size of the buffer
to allow writes to complete before the video started drawing. Following this
back to 3D (7474) still had the problem, checking the signals into 3D revealed
that one signal was very weak. replacing the chip at 3C (7420) fixed the
problem.[/font]
karlcdoe
887CR
Interesting. Anyway, I won't bother replacing a likely good chip then. Who knows what hacks are in this ROM set it would be better to start with 'known' code; therefore I'll probably put this on hold until I get a usable eprom programmer + an eraser as these are long overdue additions to my bodge it box.
4,058CR
You could send the ROMs to me. I could:
[list type=decimal][*]Dump them[*]Erase / program them[*]Before either of those, test them on a board[*]Return them[/list type=decimal]
karlcdoe
887CR
Well, as a follow up to this I finally got round to buying an eprom programmer and it was indeed the hacked ROM set that had the 'dive' sound removed
Now that's fixed an old intermittent problem has returned namely that all SFX play too fast and video looks out of sync although early (read, it was late and I was tired) tests suggest vsync is actually okay, and so are the clocks. Exciting times indeed.
