GALAXIAN PCB ISSUE
Ivandraper
5CR
Hi, I have an unmodified original Midawy Galaxian PCB. Very occasionally it will power on, last for about 5 minutes and then goes to a blank grey screen (usually it just goes straight to the grey screen). I have checked the screen chips (3A, 4A, 4A and 6A) and they aren't getting 5V, only about 2.5. The main input to the PCB is correctly getting 7V and 12V.
What I have also noticed is the capacitor at C37 is only outputting 2.5V - I changed it for a new one, but no difference. All other capacitors appear to be outputting the correct voltage.
I have also tried fitting a test ROM, but that doesn't make any difference and just goes to the blank grey screen.
Any ideas where I could test or try next would be really appreciated, thanks.
Ivandraper
5CR
Yes correct, it is using all original hardware and running 7V AC
But when I check the voltage at C37 or other components, it is only reading 2.5 volts.
I also notice the component at the top of the board above the heat sync that has the D44VM4 power transistor on it - (looks like a piece of rectangular chalk) is getting very hot. it gets warm on one of my other boards, but this one is getting very hot.
Where are the regulators located, as voltage regulation could well be the issue
Ivandraper
5CR
Hi, I have just tested the voltage regulator - 78GU1C
I didn't test it with the PCB powered up, I just tested with an Ohmmeter and diode tester and compared it against my other board. They had exactly the same readings. I would assume it would have been different if it was faulty.
Please let me know if you think I have to test with it powered on, I can seet which pin is the output (it goes to the C37 capacitor) I could then work out the input pin by trial and error I suppose
Ivandraper
5CR
OK, so I did power the board and test the 78GUIC. It is only outputting 2.4 volts, and it appeared to be getting a 15V input on one of the pins, which is odd. The issue must inbetween the PCB edge connector and the 78GUIC.
That long white rectangular component I mentioned above the heat sync that houses the D44VM4 is getting mega hot very quickly, probably to do with what ever is causing the voltage drop. I will keep investigating, but would appreciate it if anyone has any advice as I'm new to PCB repairs, which I'm sure you can tell!!!
