Galaxian Test Rom
paulcan69
946CR
I have a Galaxian single rom hacked board
Just boots to "bad ram 1" flashing
Ok nearly there...tried another ram but not sure if it was a good ram
Can test it later in pacman...but said sod it and purchased a few from Andy's Arcade as they are always handy.
Question is this, I have a 128k rom in there and it almost boots...as I pull the ram 1 out slightly I get letters and a starfield in the background so I think all is almost well.
But the Galaxian test rom is a 16k rom file which obviously goes on a smaller chip
I thought it was on a 128k rom chip when I saw Simonden's board that he brought to my house??
Is there a 128k version of it?
Does the 16k test rom file just need burning to a 16k rom chip and in another socket?
Please shine some light on this you Galaxian techs you!
Thanks in advance!!
Judder
1,009CR
At a guess I'd imagine that if your board is rewired to use a single 128k rom, then the best bet would be to take another 128k rom, make a concatenated image of the test ROM filling the 128k space with multiple copies of the 16k test rom, and then to swap in that.
Seems to work with other things like Williams Decoder chips et all
e.g.
copy /b image.bin+image.bin+image.bin+image.bin+image.bin+image.bin+image.bin+image.bin newimage.bin
  • Like
Reactions: trm
trm
2,877CR
Judder's plan is the safest one.
You could just place the image at the bottom of a larger ROM because the Z80 starts running code from address $0000 but if your fault is anything to do with the ROM select logic (now repurposed to do pseudo bank-switching for the sole big ROM) you'd get weird results if higher address lines were asserted because anything past 8kb is now $FF.
