gaplus testscreen error
kthemall
21CR
hi
have a gapuls where no sprites are shown (no foreground at all).
my testscreen looks like this. can anyone post a video or a file where i can see the boot-logic with pin1 of switch b enabled and service button switched?
my thinking is that the custom 21 is damaged as roms rams and buffers are ok, as far as i tested them
thx tom
NeonGlow
42CR
I happen to have the Gaplus on my test bench. I've enabled pin1 on the second dip switch and kept the service button grounded while switching on power, but it doesn't seem to do anything different from the usual startup sequence.
The service button appears to just add a credit.
NeonGlow
42CR
Had a look at the Operator's Manual. Looks like I need to hook up a switch to enter Self-Test mode while the game is running? I'll have a closer look at this later tonight when I have more time.
NeonGlow2020-02-19 15:04:52
kthemall
21CR
thanks, looks fine in your case. service should not be grounded but short ground like a button then pic above appears.
the 000 does not appear just a black screen until i push the service button, then my pic above appears.
hmmm, a collegue of mine has a working one, so we will interchange the custom 21 and 20 and see what happens. i´m nearly sure one of them is not working correctly.
thx so far tom
NeonGlow
42CR
Ok, the test switch is on pin 8 (solder side). It's not on the pinout from KLOV I was using.
With the game running I ground the test switch. It goes through the boot sequence but stops at the 'RAM OK' etc screen.
The service switch at this point will advance through the sounds.
Then momentarily releasing and grounding pin 8 will make it go to the crosshatch screen. Just a regular crosshatch, not like your picture.
NeonGlow2020-02-19 15:27:24
kthemall
21CR
hi
checked vice-versa with another board and it is the namco custom 20xx at 8j
looking for a 20xx in the wanted section. have one but need another one (for my collegue)
thx tom
can be closed. thx
