Garage Conversion Advice
clarkey
94CR
Hi All
Hoping to get some advice, I am going to convert my garage into a games room/ home office. The garage is detached from my house but joined to a neighbours. It has single skin brick walls and power from my house.
I'm having a side door cut in. Then the plan is to insulate the roof and walls (including one over the inside of the garage door that can be dismantled if needed.
Have some additional sockets installed.
Raise the floor slightly and insulate the floor.
For heating I'm thinking underfloor.
What I would really appreciate is any good links to guides on the better ways to insulate the walls and floor and times other people have done this.
Joe
Sciddleybop
88CR
Hi mate
I've recently done mine. There's a thread showing each step on pinballinfo forum.
But basically I got rid of the metal up and over door and replaced with wooden barn style doors which were then insulated with celotex and ply lined.
I put a plastic sheet membrane down on the floor with builders paper beneath that. Then put 2 layers of 100mm celotex on the floor in opposing directions. On top of that i put tongue and groove chipboard floor. This is known as a floating floor. I then put garage floor rubber interlocking tiles over that. The walls were then celotexed and plasterboard over, as was the ceiling. In effect you now have a super insulated room. So for heating I've found a 3kw oil filled rad does the job fine. I just put it on a couple of hours before I go out and it's toasty.
That in a nut shell was mine!!
Good luck
Gaz
Sciddleybop
88CR
It was my understanding that you only need planning if you intend to change the use of the building. Hence why I retained garage doors as opposed to bricking it up. That way if I sell the house it's still a garage. A bloody well insulated, nicely decorated with lots of sockets garage but a garage all the same!! With a slight step to get in!!
Purity
The Oracle
2,999CR
I did brick up the front of the garage, but the purpose of the building is still really the same - to store things. I don't intend living in there
