Gauge of wire for 110v?
davey d
478CR
The main factor is the current, not so much the voltage.
On an arcade/pinball machine I typically use 3x1.5mm although you might get away with 3x1mm
SUPERSPRINT
1,033CR
Indeed the current is the deciding factor. For normal lengths, 1.5mm2 will take 10amps 2.5mm2 20amps etc 1.0mm2 6amps
If power in watts,
Watts % voltage = amps.
Danscu
252CR
I should have said what it was for - its just to tap into the 110v to connect up to the lights in the topper of a twin sega sitdown cab. The wires had previously been snipped and removed.
big10p
Coins detected in pocket!
5,635CR
Whenever I need to wire something up to a mains current/voltage, I just strip the wires out from any old length of mains cable I have lying around. Then again, I'm cheap.
IanH
277CR
Me too.......
Jon-A-Tron
233CR
Ok. So if it's for a light fitting here is how to work out what cable and protection to use.
Not sure what fitting is in that topper but lets say it's 2 x 40w fittings. 80w total.
Current = Power / Voltage = 80 / 110 = 0.73amps
So you would want to protect the circuit with a fuse just above this value, so 1 amp fuse. You'll want to do this, if not already fitted, if you are going direct off the transformer so that you don't weaken the transformer every time a bulb blows.
The cable needs to carry more than the size of the fuse you use so the cable linked above should be sufficient (says it carries 3 amps)
Obviously plug in your own values depending on what you have in that topper and adjust accordingly.
bomjac
453CR
Correct Johntron, but there is a chance the 1 amp fuse could blow when a fluorescent light is powered on (most cabs use fluorescent tubes). Part of the light circuit is a ballast. The ballat is an inductor which can have high current when first powered up. So use either a 1 amp slo-blow or 3 amp quick blow.
Also - originally the question was about "guage". AWG is he US standard cable size - I would be happy to use any size larger than 24 AWG ? 0.5mm). Note that as AWG gets smaller, the cable diameter goes up.
https://www.google.com.sa/url?sa=t&source=web&rct=j&url=http://www.engineeringtoolbox.com/awg-wire-gauge-d_731.html&ved=0ahUKEwjTh-OSvLPWAhWFORQKHdCbAWUQFggvMAI&usg=AFQjCNGmQw5dUbF9PnSazEVBK2kMV9yXxg
bomjac2017-09-20 10:44:59
