Gauntlet Arcade Power
mcousins
5CR
Hi
I have recently had a gauntlet board fixed tested and confirmed working.
Once installed in the cab the boards power indicator light comes on but nothing else happens. The board doesn't kick off the boot process.
I tested the power socket pins on the 12 pin connector (as noted in the image below) running from the regulator/audio board, without the connector being connected to the main board and took the following readings:
Power Pin
1 Ground
2 +5 VDC
3 +5 VDC
4 +15 VDC
5 Reading 0.1 VDC
6 -15 VDC
7 Empty
8 Ground
9 +15 VDC
10 +5 VDC
11 +5 VDC
12 Ground
I'm getting readings off pins 3 and 4 where as suggested for the power for the board these are empty and pins 2 and 5 the sense +/-.
Should I be getting any reading from the Sense +/-?
I'll test the pin readings with the board connected and see if it changes.
[font="verdana, geneva, lucida, lucida grande, arial, helvetica, sans-serif"]
[/font]
mcousins2020-06-23 19:17:04
mcousins
5CR
So I've been back and retested all the voltages from each of the pins with the main board connected. This is what I'm getting:
Power Pin
1 Ground
2 +5 VDC
3 +5 VDC
4 +11.3 VDC
5 Reading 0.1 VDC
6 -15 VDC
7 Empty
8 Ground
9 +15 VDC
10 +5 VDC
11 +5 VDC
12 Ground
I'm assuming the 11.3VDC coming from the indicated empty socket as suggested doesn't make any difference and the minor reading from the -SENSE on pin 5?
