Hi there,
I am in the process of refurbing a Gauntlet machine, I have the PCB but the and sound board but the PPWR plug and wires have been mucked about with ie missing plug and pins straight to board the issue is some of the pins are not plugged in now so i could really do with some photos if possible of a wired up board with wire/colour locations into PCB.
Also if I could get a photo of the wires going to the monitor/screen as they are muddled as well.
I did find the below on http://www.ionpool.net/arcade/gauntlet/tech/gaunjam.txt
but I don't know which is # 1 as you can look at the plugs from 4 different directions
Any and all help welcomed.
**POWER**
**POWER**
Code:
Tis is the large white 12 position plug layed out like this:
|1 4 7 10|
|2 5 8 11|
|3 6 9 12|
Connect these to JAMMA as indicated below:
1 GROUND JAMMA GND
2 +SENSE JAMMA +5v
3 EMPTY
4 EMPTY
5 -SENSE JAMMA GND
6 -15V DC JAMMA -5v
7 EMPTY
8 GROUND JAMMA GND
9 +15V DC JAMMA +12v
10 +5V JAMMA +5v
11 +5V JAMMA +5v
Code:
[size="1"]12 GROUND JAMMA GND on the[/size]
