GBS-8220 Issues
KevW24601
9CR
Hi there,
Recently I have modded my Arcade1Up cab to a JAMMA cab. It's mainly been smooth sailing but I've hit a snag with the GBS-8220 CGA to VGA converter board and was hoping you guys could help. Details below:
I am using the stock 1Up monitor (M170ETN01.1) with
the same LCD Controller board used by ETA Prime and I have the GBS-8220
converter board that I need to use to get the CGA JAMMA signal to output
on the monitor via VGA. I have the 5-toothed video pins (RGB, Ground
and Sync) from the JAMMA Harness connected to the relevant slot on the
8220 and I have the 8220 connected to the +5v and Ground slots on the
Arcade Power Supply.
When I turn everything on,
I get the Chinese letters on the screen to show that the 8220 is
activated. Then I either get a message saying "No Signal" or a solid /
fuzzy green screen (depending on the JAMMA board - I have two of them).
None of the settings on the 8220 rectify this save for making the
fuzziness more prominent.
The JAMMA boards
are functioning fine apart from that because the game sounds come out
of the speaker and all of the buttons work, so it seems to be purely an
issue with the GBS-8220.
I thought it was that
the 8220 did not like the stock monitor so I borrowed my neighbour's PC
Monitor and hooked it to that instead, but I had the same results.
And
I haven't found any solutions on the web or YouTube either. There's
either the videos and links that show it working perfectly, or videos
and links where people are having the same problem with it that I have
but with no discussion or explanation of solutions so I'm at a bit of a
loss.
Would you happen to have any ideas of what I can do to sort this out or what do you think the problem might be?
RaveN
1,325CR
Ive broken a lot of them. They have no form of input protection and seem to break everytime the video TTL voltages overshoot a tad (that's what I'm assuming anyway).
KevW24601
9CR
Purity said:
I don't know what your specific problem is but the GBS-8220's are rubbish, and not worth bothering with in my opinion.
Seems that way. I've researched all over last night and have found that they tend to be very hit-and-miss in terms of if they work or not.
Are there any alternative CGA video converter boards I should consider?
KevW24601
9CR
gunblade said:
have you checked its on the correct video input setting
have you auto scanned yet?
I've cycled through all of them. RGBS gives me the solid green screen, the others just blank. Auto scanning it just sets it to RGBS automatically.
I've also tried experimenting with the different display resolutions and the "Clamp ST / Clamp SP" settings that cause issues with certain games.
KevW24601
9CR
dromero said:
Hi, tell me were you conect the RGBS from the jamma to the decoder 8220s
Thks
There is a vertical five toothed pin slot at the bottom left corner of the converter board. That's where you slot in the RGB, Ground and Sync connection from the JAMMA.
Just an update on my end, I got another converter board to replace the one I had, it worked with no problems. So faulty board obviously.
