Geometry Issue Top Right Only!!?
lettuce
13CR
So on my JVC Broadcast monitor i have notice that the screen slants down slightly at the top right of the screen all other corners are straight its just this top right corner that slants down. There also seems to be an ever so slight discolouration in this corner when on a pure white screen, there are no speakers or the like near by and have tried moving the monitor into different positions and it doesn't remedy the issue.
Am i right in thinking getting magnetic/convergence strips and placing them on the rear of the tube in this corner will fix this slanting issue as rotating the tube slightly wont fix the issue as this would then send the other 3 corner out of alignment?
Ropi Jo
127CR
You can check that the scan coils (yoke) hasn't become loose and slipped out of position. Back in time had plenty of geometry errors due to the yoke being just a few mm back from the tube. Should be hard up against the back of the crt. A degaus is always worth a shot too.
Ropi Jo2018-09-22 23:19:43
