Germicidal Bulb for EPROM Eraser
lix
546CR
I have a 5 foot UV-C tube which does indeed do the job on at least 50 EPROMs at a time. I got a bulk load of chips from a closing down fruit machine operator and thought it would be handy to erase them. The tube took several attempts to receive, largely because I bought it mail order and couriers would gladly throw the 'protective' cardboard tube against the wall or see how much they could bend it to make the crunchy glass sound.
I set the tube up in a room with an extension lead going outside of the door so I can power it up without exposing myself to the dangerous light. It does convert most of the oxygen to ozone though, at least it's very antibacterial / antiviral.
offset
26CR
Learned some about UV-C during Covid (room disinfection), heard about the benefit of rom erasing recently. I have one of those cheap chinese eeprom erasers, didn't think too much about it having a small uv-c bulb in it.
No joke about being careful around UV-C, harmful to humans, animals, plants, anything with DNA, plus may discolor some things.
Make sure to use a UV-C bulb that doesn't generate ozone (unless you want to vent the room before entering to check on your eeproms)
offset
26CR
ColinD said:
Can you can a small UV LED torch for about £10 or so.
Found myself buying a UV-C tester as I didn't trust whether my setup was actually putting out UV-C wavelength. https://www.quantadose.com/product/quantadose-2nd-edition-reusable-uvc-test-cards-300-%c2%b5w-cm%c2%b2-minimum-intensity-w-uvc-wavelength-indicator/
I've heard there are counterfeit uv-c bulbs that don't put out the correct wavelength.
I've personally used the stuff from Coospider but only for disinfecting a room (rotate through rooms) - https://coospider.com/collections/36w-uv-lamp
offset2022-01-06 18:43:55
galaxian68
5CR
About 20 years ago I bought a little portable florescent torch from Maplin, replaced the tube with one for a fish tank steriliser.
Worked fine to erase eproms in a shoebox lol.
