Glitches on a multi williams
retroshaun
54CR
[uk-vac] Glitches on a multi williams
Hey guys..
My multi williams has some annoying glitches across the top and down the right side of the screen (in every game and the menu - tho the degree of "glitchiness" varies from game to game).
Anyone know what may cause this? Is it "normal"?
http://www.flickr.com/photos/54651860@N00/104717043/
http://www.flickr.com/photos/54651860@N00/104717042/
Thanks!
To help you stay safe and secure online, we've developed the all new Yahoo! Security Centre.
retroshaun
54CR
Re: [uk-vac] Re: Glitches on a multi williams
That would help the X but the glitch on the top of the screen is actually over the game display (the scanner area in Defender, for example) - perhaps that wasnt totally clear on the images. Its also often a lot worse than the image shows.
Shaun
david_orton_2000 <david_orton_2000@yahoo.co.uk> wrote:
G
Guests
Guest
[uk-vac] Re: Re: Glitches on a multi williams
Hi,
Is this the 'multi williams kit' that adds on to an existing game board, or is it the multi williams 'jamma board' ??
This could be some 'foldover' as iirc there is certainly a bit of noise 'off screen' on a real boardset... so it's quite possible that the monitor is at fault and is folding the off screen noise over the picture (does that make sense ?)
See if you can reduce the height of the screen and see if the noise stays where it is, or stays in the same position on the scanner area /display.
Cheers, Colin
Subject: Re: Re: Glitches on a multi williams
Shaun
david_orton_2000 wrote:
