gorf missing transformer ?
vids
143CR
i am trying to find a suitable replacement transformer for my gorf upright details in this link i put it in restoration instead of tech forum
http://www.ukvac.com/forum/gorf_topic351352.html fingers crossed for some help
DanP
Administrator
2,232CR
Not entirely sure what you're asking for here? Are you asking for a replacement for the whole transformer brick, for the missing transformer on your existing brick or what? Finding an entire brick will be tricky. You need to trace where those cut wires connect to. From a quick look at the manual one is for the game boards power and the other for the monitor. Which one are you missing?
vids
143CR
Hi dan thanks for the reply its the one to the monitor im missing, i get power at the board cage connection thanks
DanP
Administrator
2,232CR
Cool, that's by far the easiest one to replace. Do you know what monitor it is you have in there? Is it a Wells Gardner 4600? I take it that it doesn't get any power going to it at the moment? Easiest fix if so would be to add another isolation transformer to just power that separately. jengineer on here will probably be able to hook you up with something if so.
Cheers,
Dan
vids
143CR
Cheers,
Dan
its this one and no power going to it at all
help is appreciated
DanP
Administrator
2,232CR
You could *probably* use that transformer yes. As I said before, all you need is an isolation transformer. It will need two (maybe 3 if it's earthed) wires going in providing 110 or 240vac and will output 110-120vac @ 50hz. Your monitor is a Wells Gardner 4600 which seems to tolerate 108 - 132vac as it's input voltage. Looking at the schematics provided on that auction it seems to provide the voltages you need on the 6 pin plug (with yellow wires), although you'd need to check that it's jumpered for 110 or 240vac input operation. The Gorf schematics seem to show that the original isolation transformer in there took a 115vac tap off the other transformer (from a blue wire) into the transformer you're missing. You can either try and wire it like that or take another input source voltage (say 240vac) for the input voltages for the monitor transformer.
I don't know any of this off the top of my head, it's all available in the manuals and schematics for Gorf, the 4600 monitor and the kindly person selling that transformer on eBay :)
If I get time in the next few days I'll try and take a picture of my Gorf's PSU to try and show you what it's supposed to look like.
HTH
Dan
vids
143CR
HTH
Dan
yes that is a great help i shall get my old tv repair friend round to take a look i really don`t like fiddling with anything to do with monitors
thank you dan
vids2016-08-20 11:39:50
