Gorf owners
bonehead
I'll get pix tonight
50 (100%)
1,729CR
hi all, I have been looking at my upright gorf I got last week. After a long time we realised it had the wrong power pcb in it from another game which was faulty.
I have tested the pcb stack, RGB board in my cocktail gorf so know they work.
Fitted the power board into the upright, pcb stack, rgb board. Powered up with no monitor as I am missing a lead from the rgb board to the monitor.
Ga,e credits and the rank lights work but no sound!!!!! Tried the volume pot for both speakers but nothing.any ideas where to look? I guess the sound comes straight from the stack pcbs?
Also as I mentioned I think I am missing a lead from the rgb board to the monitor. I have a connector on the loom which goes to one side of the rgb but no lead from the other side to the monitor.
Can someone look at their machine to confirm if it is a separate loom to the monitor please?
Also if so does anyone have one I can buy please?
I am also going to add a switcher mod to remove problems with the power board.
Thanks,
Steve
Hurray Banana
2,755CR
With my audio board (the one with the pots)
I had to replace the following components to get sound working after it failed completely. look at the schematic in the manual for the detail.
Replaced 330 ohm resistors at r4 and r1. Replaced 4004 diodes at cr1 and cr2. Replaced 2n4403 pnp transistors at q1 and q2. reflowed solder for tip31's. Most of these are standard pinball transistors and diodes so luckily I had spares to hand.
As for video, some of the cables are grouped with other cables going up to the rank lights, but here's the cable coming from the output connector of the video board. Hope this helps a bit, can't get to the back any better at the moment.
RGB board output
monitor input - can't see (too bloody dark) to very where all orange and white connectors come from in the smaller connector
rgb output, white wires (3 of terminated)
bonehead
50 (100%)
1,729CR
Thanks for the pics and info on the sound amp.
I tried it in my cocktail and I got impressive smoke and flames from a cap that bridges the 2 tip transistors.
I will start rebuilding it and report back.
Any idea what pitch the connectors are on the G07 monitor so I can make up a loom?
Thanks,
Steve
LAZORIAN
260CR
I dug out my loom and the connectors are exactly the same as HB's, intertwined in the loom. It has the same coloured wires going to the same pins too, its very odd your loom doesn't have them.
Just a thought... have you checked the speakers? The cones are split in various places on both of my original ones, they haven't been tested but might be worth giving yours a look as well as the amp.
Hurray Banana
2,755CR
on the monitor from what I remember the're the same pitch as williams (used the same type on my robotron) connectors 0.1 inch. I've just pulled mine it's a 6 pole connector and a 3 pole connector
Hurray Banana
2,755CR
Steve said:
Ok thanks I will check my parts box. On the power board I think they are .156 pitch.
I will go and check the speakers.
Arghh steve you are probably right the 0.1 are probably the ones on the rgb board as they are definitiely finer pitched. Like I say standard williams size which is what you've stated .156 inch
Hurray Banana
2,755CR
Arhh steve you are probably right the 0.1 are probably the ones on the rgb board as they are definitiely finer pitched. Like I say standard williams size which is what you've stated .156 inch
bonehead
50 (100%)
1,729CR
Hi, sound sorted now.
It was the cap which bridges the two transistors.
I don't have .1 pitch so will order some.
Next question if that's ok?
One set from the cocktail don't seem to work correctly in the upright but another set do? It's hard to tell what's going on yet as I have no monitor in the upright. Is there 2 to sets and you need the correct set to work in the upright as opposed to the cocktail?
Just trying to eliminate a few things as I would like a spare set of pcbs for the upright.
Thanks again,
Steve
Hurray Banana
2,755CR
Don't know for sure about that Steve but the manual has the same part number
a789-00002-0000 for all 3 versions of Gorf so I assume it works out if its in the cocktail when the extra controls are connected for player 2.
