Hi, a gottlieb street fighter 2 pinball has had an LM338 regulator fail. The problem is that it has gone closed circuit meaning that 12v has been sent everywhere that the 5v goes. Unfortunately gottlieb apparently chose not to put any protection against this for the first time on this generation of machines, they did again after unsurprisingly.
What sort of damage am I looking at here? Does this mean that all the chips on all the PCBs are fried?
If it is a worst case scenario would a complete set of new PCBs even be viable bearing in mind the pinball is probably only worth £2000 fully working (seen a couple of much higher prices but Liberty games are way off the mark compared to actual sold units)
If you do own a pinball of this generation it has been recommended elsewhere to remove the small PCB with the LM338 on it and install a normal arcade switch mode PSU using only the 5v to power the machines 5v through the old PCBs output plug instead.
