Gravitar High Score save
Monstermug
1,807CR
I am pretty sure Gravitar saves the highest score but mine doesn't seem to do so. On power off, scores are wiped.
I have checked pin 14 and pins 6 of the ER-2055 chip and getting the correct voltages which were -28v and +5v respectively. I changed it out for a new one and still doesn't save high scores. Am I missing something? Could it be the new ER-2055 is bad? Worth getting a new one or should I try something else?
Oh and I have changed the electrolyte capacitors on the board too.
It is set on freeplay if that has any effect?
Monstermug2016-11-14 16:55:37
Monstermug
1,807CR
Doh! Can't switch it to coin atm cos it's missing service panel/coin bucket and coin mech! Thanks. Been puzzled over this for last few days.
It's wierd cos space duel still saves on free play. I thought the same would apply.
DanP
Administrator
2,232CR
Sorry I think you misunderstood me. Putting it in free play will have no effect on the hi score circuitry. By this I mean that in free play it *should* still store hi scores.
Monstermug
1,807CR
I finally had some spare time to work on this problem today. Kinda annoyed that the high score wasn't saving (not that I could get much of a high score anyway :p).
I had previously replaced all the capacitors on the board so there was no need to look there. I had also confirmed that the EAROM was receiving the -25v. (I stuck it in my space duel for an insanity check and it was indeed fine)
Wanted to go into test mode to confirm that is indeed an error but couldn't as my Gravitar is missing the coin box and service panel, I am unable to go into test mode without hooking up the connectors and jumping the test pins. Anyway, I couldn't be bothered to do that and just decided that it was indeed a fault.
Looks like this pcb needs some careful probing.
Pulled out the schematics and found a convenient High Score Table datasheet. First tested the 555 Timer. Then the LS174 and LS175. They were both fine. Only other chips on the High Score schematics were the LS244 abd LS374 buffers. Decided to test the LS244 and that was fine. When I tested LS374 found that it was bad.
De-soldered the guy out and socketed a new LS374 in.
Plugged it in and it worked!
Gravitar now saving high scores.
Hope this helps anyone with the same problem.
