Hi Guys !
I am trying to fix a Gravitar board. It was watchdog-resetting, and after a lot of effort, I finally found out that the pokey was messing with the address lines. After removing the pokey, the board boots but the vector address custom chip is dead, so I replaced it with a BXAVG, and I now Y output. X, however, is at zero volts.
A10 (TL082) was very hot, so I replaced it. Still no output, so I suspected the DAC. Replace it with a socket and a new DAC, same issue. The suspect is now XREF signal, which is always at 0V. This is weird, because YREF is just fine. The ref signal, available on R165, R166, R167 and R168 is ok. On the other side of R166-R90, YREF appears perfect, but the same circuitry R167-R91 gives 0V. Removing the DAC restores the signal, as expected (the resistors are fine). Since this is a brand new DAC, I have a hard time believing that it's also dead (I ordered 3 dacs, checked with 2 of them, same result).
The power rails are all fine, checked at the DAC pins. Removing the op-amp or the LF13201 doesn't help either.
Any clue ?
-Fred
Any clue ?
-Fred
