Groovymame help!
RygarR
412CR
Hi Everyone,
I have an ongoing issue with Groovymame on two different machines. At random, but most often after a power off, the hi-score table on the game I'm playing resets. Thank goodness for Arcade Sidekick!
I was wondering if this is just a glitch, or if there could be some wierd combination of button presses I'm not aware of doing the erasing?
Cheers.
frothmeister
58 (100%)
938CR
Do you mean the highscore tables reset to default, or back to where they were before you started your session?
I think you do need to exit back to the menu after each session for your scores to be saved next time you boot up the same game.
RygarR
412CR
Thanks,
I mean to default.
I do often shut down by powering off from within a game. My Windows set up is read only, so it's safe. Most of the time, the hi-scores are carried over fine. Just occasionally, however, restarting the game resets them to default...
RygarR
412CR
Possibly, Rich.
I do have the 1P start and 1PB1 combo set up as insert coin. Perhaps hitting that too soon, or holding it down by accident triggers the reset? I'll experiment later...
RygarR2020-12-17 14:53:56
tronads
453CR
I wonder if the power is being removed at the exact moment the file is being updated, corrupting the file, so on next play its having to create a new file.
Its not something I have ever experienced, but I always escape back to the front end before switching off, even though I have the same read only configuration.
Maybe see if you can get into that habit and see if its still happening.
RygarR
412CR
Yeah, possibly. I'll keep an eye on that.
RygarR
412CR
While playing on Black Tiger earlier this week, something strange happened on my Groovymame cab.
I'd started the ROM, while chatting with the wife - and automatically went through the coin-up combo without looking at what I was doing.
When I looked back at the screen again, a strange console had opened up. Not the normal one you access through the 'TAB' combo. It was one I'd never seen before - with tonnes of options. I pulled the keyboard out the cab and carefully 'escaped' out of it. But it seems that inadvertant button-mashing by me - whilst talking to the wife - has deleted at least a couple of settings. Frutsratingly, those include the combo for volume control, and the one for 'TAB' - meaning I can't get into the regular settings. Aaaaarrrgh!
I wonder if it was a combo in that mysterious console which was getting button-mashed before - and resetting my high scores? I suspect that my phone might have been resting on one or more of the P2 buttons, making that kind of thing more likely.
From now on, I suppose I need to be a bit more carefull!
But I also need to reset the key combos for all the GroovyMame consoles. Does anyone know if there's an easy way of doing this? Or will it mean reinstalling mame on my Cab's PC. And if that's the case, is there a way of exporting my favorites list, so i don't have to spend hours picking them out from in between all the fruity and mahjong titles?
Noobular, I know, but any help would be appreciated...
