Groovymame Projector setup
Ravi_s
7CR
Hi Guys,
I would like to setup groovymame using native 15khz resolutions on a projector. Is this possible ? I assume I would require a very old projector? Or I can get one of those led pico projectors with a native resolution of 320 x 240?
Thanks.
Ravi_s
7CR
Thanks for your help.. I guess I will chance it on one of those Chinese pico led projectors .. I guess better to match or down scale to native 320 x240 then upscaling to native 720p. What do you think? Ravi_s2014-04-23 20:49:31
Ravi_s
7CR
My fav all time game street fighter II champion edition.. I think it runs at native res of 384 x 224 on my arcade cab.
cools
I joined ages ago honest
19 (95%)
798CR
You dont want native res, trust me it will look horrendously pixelated.
2 years ago at a meet we had SSF2T on a supergun hooked up to my Epson TW10H and it looked astonishingly good. The screen door effect of having the LCD zoomed to max gave a striking CRT type image and there was no problematic lag.
Ravi_s
7CR
I was thinking trying to beam at close to native resolution as possible at about 50 inches.. This should look ok... Rather then stretching / scaling the image to native 720p.Ravi_s2014-04-24 08:50:12
cools
19 (95%)
798CR
You're thinking backwards about this. On anything other than a CRT you want to be running at the display's native resolution rather than the games resolution - and then feed it a well scaled image.
Any projector has a native resolution. Your PC needs to be set to this native resolution, and then GroovyMAME needs to apply unfiltered integer stretching.
It's exactly the same thing you'd do with a flat screen display.
The only trouble is that SF2 doesn't have square pixels, so your image is going to appear flattened.
http://retrogaming.hazard-city.de/
cools
19 (95%)
798CR
Good luck! In fact the higher resolution the projector the better, as you may be able to get away with scaling non-linearly without it affecting the image for non-square pixel games. It's the scaler that's the key ;)
Ravi_s
7CR
Just a quick update .. Tried mame on my Optoma 720p... Beaming at about 110 inches..I switched on HLSL - changed with various setting to do with scanlines and turned off bi-linear setting.. To get rid of the blur... so the picture was so razor sharp. The end result was simply amazing! The picture was very similar to my CRT. I felt like I was playing street fighter 2 on a massive arcade cabinet with crisp picture complete with scanlines. I am temped to dump my cab... I think LCD / projector may well be the future for mame, provided you have a decent i5, i7 PC. Ravi_s2014-04-27 16:27:31
ZedEx48K
8-Bit
1,421CR
Well since I have a proj and an OC i7 I think that's me sorted :p
I did use to play mame out on the proj but the reality is you need to have a good couple of hours session to be viable, it's not great on the bulbs over time to have a quick go here or there turning it on and off.
