Ground loop hum
RygarR
413CR
So, I've got a MAME PC in my cab, with the audio out fed directly into a small amp and then through a jpac into the cab speaker. Sound quality is mostly great, and loud enough to have to turn down. Only problem is an audible ground loop hum when the speaker is otherwise quiet.
As it happens I had an old ground loop isolator lying about. When I connect it in between the jpac and the speaker it kills all trace of the hum, but also knocks out a half or more of the total volume. If I connect it in between the PC and the amp, on the other hand, the volume is intact, but so too is the hum.
I read somewhere online, that this kind of problem can sometimes be solved by extra grounding. Question is, where is the best and safest place to attach the wires? Any ideas?
big10p
Coins detected in pocket!
6,085CR
I had this issue. Ground loops can be a right PITA to track down.
The only difference to your setup is that I have the amp wired up on the harness side, rather than between the PC and JPAC. Anyway, I could meter a slight voltage on the PC frame ground, so I connected one end of a wire to GND on the JAMMA edge (using a pass-through adapter), and connected the other end to the PC's I/O backplate, using a croc clip. Sorted!
Can't promise this'll work for you, but worth investigating.
obcd
3,830CR
Disconnect the pc jack and short the inputs. If you still have the hum, it's the amplifier or JPAC generating it. An unstable 12V supply to the amplifier can also cause hum.
An extra ground wire from the pc case to the amplifier supply GND is indeed never a bad idea.
I agree it can be a pain to troubleshoot.
RygarR
413CR
Thanks guys. I'll give all of this a try when I'm back tomorrow. As the amp is only 5v and powered off a USB header, I'm guessing that the jpac might be responsible. But I'll break out the croc clips and paper clips for some ghetto grounding experimentation.
big10p
6,085CR
obcd makes a good point about power supply to the amp. I got a hideous hum when I initially had my 12v amp connected to the JAMMA switcher, without a load on the 5v rail.
Might be worth metering the voltage on the PC header you have the amp connected to. Also, you can only pull 500ma max from USB. Maybe your amp requires more to function properly? Try hooking it to +5v on your switcher or the PC PSU.
big10p2016-02-03 11:30:26
