Grounding Issue
ataridude74
265CR
Should be a simple question.
The white colour is very feint on my monitor, reds greens and blues are fine.
When I press any button (L,R,Fire,P1,P2) the white goes back to normal, and the whole screen gets brighter.
I suspect a weak grounding issue.
The buttons are wired to Video Ground, which is connected on the PCB to logic ground.
Can I wire them straight to ground from the switching power supply? Ground is ground, right?
It's a Sega/Gremlin Moon Cresta PCB (DC converted).
I think I know the answer, but having had SO MANY problems with this game and various PCBs I am not taking any chances.
Titchgamer
123CR
I am no expert but I dont think you should have your inputs connected to video ground, I would imagine there is a reason it has a separate ground to the rest?
RaveN
1,325CR
Ground is ground yes, but it has to be carefully wired otherwise you can have ground-loops or noise induced, which would be most noticeable on the video and audio. You would typically follow a star-topology to ensure a proper reference ground potential.
Wire the common contols ground straight to the PSU.
