Grounding
Rawsome
lost my cab cherry
72CR
Hi, when you ground arcade buttons, the diagrams that I've looked at normally have three terminals on the button. Mine have two. What's the protocol for grounding gold leaf buttons?
cosine
14 (100%)
595CR
Shouldn't matter which way they're connected I would think, I use sanwa buttons (not entirely the same I know) and they don't care so long as a contact is made when the button is pressed. If anything, I make sure the ground is connected to right side terminal of the button on all of them, so it's consistent.
Rawsome
lost my cab cherry
72CR
Thanks, I was waiting for someone to say what I was thinking. I appreciate your response
Rawsome
lost my cab cherry
72CR
Thanks guys, that helps a lot. However, I have another problem now. The buttons fit a 4.8mm crimp, but the joystick has much bigger connectors. Would I be ok to make some extensions and connect via male to female crimps once I found out what size I need?
Here's a couple of pics to show what I mean.
Rawsome
lost my cab cherry
72CR
If anyone knows what size crimps would be needed for this, that would be awesome. The joystick is a Mag Stick if that helps.
Thanks.
