Grounding
RygarR
413CR
Morning Guys,
My horizontal jamma cab has always had some very slight distortion on certain games. Particularly, and annoyingly, the hi-score table for Robotron. It also has a bit of a buzz from the speaker when no other sound is being output. I'd always assumed this was just the age of the components. Recently, however, I've been practising Robotron for the 10p arcade game of the month on my JROK (submission imminent!), and there's no distortion and no buzz whatsoever. Then I realised that the cab's almost always had a PC and jpac in it, at least a couple of both. So, I'm wondering if this could be a grounding issue, and if it is, if hooking up an extra ground wire somewhere might cure it?
Any ideas?
big10p
Coins detected in pocket!
6,093CR
Some kind of ground loop issue, probably. Had lots of 'fun' myself trying to sort this issue myself, in the past. Can be a bugger to track down. Try connecting ground on the JAMMA edge to the PC backplate. I basically just connected a temp wire to ground on the edge, and went round touching it to other ground points in the system to see if it made a difference.
Also, if your monitor frame has a direct earth connection, try disconnecting it.
big10p2019-05-13 11:36:22
RaveN
1,325CR
Remember the star ground topology.
A single point for each seperate ground return to meet, or ensure that the return paths with higher current are closer to the central ground location so that they do not induce voltage in the smaller signal paths.
The other issue is whether the ground point should connect to earth, and if so how, which is determined by the particular setup.
RygarR
413CR
Thanks Raven. Beyond a module in electronics about 30 years ago, my knowledge is pretty limited. I'd better do some reading.
