Hi Guys,
Will probably post in a bit more detail, when I get chance (weekend maybe), to include photos etc, but thought it was worth putting this out now as you never know, one of you clever peeps might be able to help straight away.
So prior to taking my upright GTi Club to bits to clean, etc, it all worked, and now, inevitably, after putting it back together, it doesn't!!
It did have an issue with a vertically jumping monitor but a slight adjustment to the v.hold has fixed that, however I am now looking at the FFB not working CORRECTLY.
So, after putting it back it did all work fine, no errors. Then when I was in the settings menu, changing the number of laps, difficulty, etc, I saw that the FFB was set to light, so I changed it to medium to see what it was like, then to heavy. Then I switched it off for that day.
Turned it back on the next day and on the initial start up, the ROM checks are all fine, then it goes into the steering check and the FFB motor "stutters" (is the best way to describe) as it struggles to go from right to left and back again. Eventually ending in an error screen. Previously it would graciously swing the wheel to each extremity.
Skipping the error and going into the game I have no FFB in game, but set a score and on entering you initials, there is. There also is on the initial menu select screens where you choose your car and track.
Also id the I/O check screen wheel is no longer showing centre, when it is, if that makes sense.
So it's not dead, just not doing what it should. I will of course check the wiring when I get chance and reseat any connectors on the FFB and also the three wires on the motor pot could be better soldered, so will probably redo those too.
But just wondered what you guys think? Or any tips you could give at this early stage.
Thanks in advance.,
Neil
Thanks in advance.,
Neil
